Forum > Autohifi > Clif Designs
 o Navštíveno 2431x o
o 15.02.2008, 11:24 | Yawor
Přátelé nemáte někdo zkušenosti s touto značkou ?
Myslím tím výrobky /zesilovače/ mladší cca 5ti let, tedy poté, co se firma hnula směrem do asie.
Na US forech jsem toho moc nenašel...
Díky za jakékoliv info
o 15.02.2008, 11:28 | Martas
brzy budou nějaké info možná i recenze od jednoho zdejšího člena :-)
o 15.02.2008, 11:34 | Cenda
ty, Drevaku, neresil to tady nekdo pred par tydny?
o 15.02.2008, 12:03 | Yawor
cenda : vím, tam byl ale dotaz na kompa
druhý dotaz je 1/2 roku starý od té doby se mohlo stát lecos ;o)
Martas: btw sej si pak u těch komp bacha na obsah...
výcuc:
Let me tell you something about the QX6500C's.
Run. Away. Quickly.
I am familiar with the 'old' Clif Designs from years past. I actually met the president out in California when I was stationed there. (USAF) He was a great guy and answered a lot of questions I had about his Dodge Stealth install.
Years later, I figured I would check them out at CES. Once again, the company was solid, had great speakers, and super installs. That was maybe 7 years ago or so. (Same vehicles can be seen on CDT's website... coincidence?)
So recently I went out and looked for a new set of front speakers. I saw the Clif Designs QX6500C's and thought "Man... I loved my old Clif's. I'll give them a try."
The box they came in was pretty impressive. That's about it.
The wiring was terminated with all 'male' connectors. It's really hard to hook up the speakers if the wiring doesn't connect right. Minor issue, but still... for $800 they better be perfect.
The crossovers didn't come with screws to mount them, and the crossover PCB was loose from the rest of the frame. Maybe some really large screws with some fender washers would work?!?!
The 6.5 drivers have mounting rings and grills that look pretty cheap. They came with screws to mount the rings... but no screws to mount the driver to the rings. Doopt! Once again a minor issue, but...
The tweeters have three mounting options. Surface, flush, and flush angle mount. Instead of a clamp/screw type retaining system, they use a big azz knurled ring to clamp the tweeter ring in place. Kinda like those toy wagon clamp style nuts that hold the wheel on the axle, only bigger. Oh yea... it doesn't work with the flush angle mount. You're out of luck if you want to use that mounting option. By the way: no additional screws are provided for the tweeters, either. Too bad if you want to use the angle mount... unless you decide to hit Home Depot for some custom mounting hardware.
I sent two e-mails to Clif Designs looking for answers. I got NOTHING in return. Nada. Zip. (Yes, I checked my spam folder.)
I ended up returning them to Sonic Electronix. I told them I wanted to exchange them and get the Pioneers instead. Last night, I got another set of Clif Designs.
Guess what?
Wiring is the same, the screws are not there, crossover PCB's are not held in place, ad naseum. Clif Designs has poor quality control if you ask me.
I will be returning these again... but now I am $25 down for return shipping.
Mark
p.s. CDT is the "old" Clif Designs. I looked at some old crossovers I had, along with some older drivers. They look the same as the CDT's... but how the name change happened I really don't know.
mně osobně jde o Clif Designs CD4800.1LX
o 15.02.2008, 12:04 | Yawor | Upraveno: 2008-02-15 12:05:21
double... pls del
o 15.02.2008, 17:19 | Squere
hm zajímavý necháme se překvapit až přijdou (kdyžtak je sem nafotim), byli testovaný v nějakym USA carhifi časáku a hodnocení bylo průměr ve své třídě btw. to znamená 800-1000USD a za tu cenu za kterou přijdou si myslim že to bude hodně podobná kvalita reprum co se u nás prodávaj za podobný prachy za který přijdou
o 16.02.2008, 12:10 | Yawor
ok, pls pak napiš nějaký zkušenosti
o 27.02.2008, 17:42 | Squere
foto k příspěvku  od Squere
o 27.02.2008, 17:43 | Squere
o 27.02.2008, 17:44 | Squere
o 27.02.2008, 17:45 | Squere
o 27.02.2008, 17:46 | Squere
o 27.02.2008, 17:55 | Squere
na výhybce mě překvapil samostatnej vstup jak na středobas tak na výškáč
o 27.02.2008, 17:56 | Squere
o 27.02.2008, 17:57 | Squere
o 27.02.2008, 17:58 | Squere
a nakonec všechno pohromadě :-) toť vše :-) zpracovánim se mi moc líbí, uvidíme jak na tom budou zvukově
o 27.02.2008, 18:31 | Martas
no je to fakt nádhera, pak dej vědět jak hrajou
o 27.02.2008, 21:11 | cendler
Tak ty vipadají luxusně, jako Martas pak poreferuj jak hrajou
o 21.05.2008, 13:08 | Yawor
squere : tak co zkušenosti ?
o 22.05.2008, 08:49 | Squere
ahoj, no pokud bůh dá tak se do auta dostanou do měsíce, auto mam od zimi pořád rozebraný :-( jinak hráli mi teď v pokoji, radio bylo JVC KD-SH 1000 signály Sinus live CA zesík Denon DCA 600, akorát musim předělat bedničku na kompa, protože nebbyl čas tak sem to hodil ddo společný a stojí to zaprd, budu teď dělat bedničky , 4,6,8 litrů a poslouchat který objem bude sedět nejvíc. Výšky se mi moc líbí, ale bojim se toho že to bude hlavně tim že to hraje v místnosti a v autě se ten zvuk podstatně změní. až bude čas chci vyzkoušet ještě bi-amp s dvoukanálem DCA 500, zatim se mi ten zvuk hlavně z výšek opravdu líbí, hodně slušný detaily, i když to zatim nebylo v optimální sestavě, toť zatim vše, až to bude v autě, tak se ozvu :-)
o 22.05.2008, 08:53 | Squere
o 22.05.2008, 08:57 | Yawor
:o)
oki, díky za info, za měsíc tě zase budu bombardovat :o)
Stránka vygenerována za 0.3058 sekund.
