Forum > Autohifi > Kolik to ma cenu?
 o Navštíveno 1848x o
o 22.09.2007, 23:06 | imax
Zdar chci se zeptat kolik by ste dali zo rok pouzivanej zosik audison srx5
POWER SUPPLY
Power supply voltage: 11 ÷ 15 VDC
Idling current: 0.9A
Idling current when off: 0.002mA
Musical max consumption: 40A
AMPLIFIER STAGE
Distortion - THD (1 kHz; 4 Ohms): 0.05%
Bandwidth (-3dB): 4 Hz ÷ 50 kHz
S/N Ratio (A weighed @ 1 V): 95 dB
Damping factor (1 kHz, 4 Ohms): 90
Pre IN input senstivity: 0.2 ÷ 5V
Speakers IN input sensitivity: 0.4 ÷ 10V
Pre In input impedance: 15 kOhms
Speakers In input impedance: 100 Ohms
LOAD IMPEDANCE
Front and Rear/Sub: 4 - 2 Ohms/4 Ohms
NOMINAL OUTPUT POWER (RMS)
NP @ 12VDC; THD 0.3% 4 Ohms: 45W x 4 + 140W
OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%
5 ch (4 Ohms): 50W x 4 + 180W
5 ch (4x2 Ohms + 4 Ohms): 75W x 4 + 180W
3 ch (4 Ohms): 150W x 2 + 180W
FILTERS/INPUTS
Front Input: Pre In / Speakers In
Rear Input: Pre In / Speakers In (on/off)
Sub input: Pre In / Speakers In (on/off)
Front - L/R filter: hi-pass 12dB/Oct., 50 ÷ 220 Hz
Rear - Woofer filter: hi-pass 12dB/Oct., 50 ÷ 220 Hz
Multichannel filter: hi/lo-pass crossover, 12dB/Oct., 350 ÷ 6000 Hz
Sub filter: lo-pass 24 dB/Oct., 50 ÷ 220 Hz
MODE switch:
5 ch: FR (hi-pass front / hi-pass rear / lo-pass sub)
5 ch: MC (hi-pass mid-hi / band-pass woofer / lo-pass sub)
3 ch: 3C (hi-pass right / hi-pass left /lo-pass sub)
OTHER FUNCTIONS
Remote IN: 7 ÷ 15 VDC - 1 mA
Connections for VSR kit for SUB remote volume: optional kit
Fuse: strip, 30A
Protection: temperature > 85oC, DC voltage, overload
Green-red LED indicators: on-safety
Cooling fan: if activates from 55oC on
MAX SIZE (D x H x L): 178 x 49.5 x 440 mm
WEIGHT: 3.3 kg
foto k příspěvku  od imax
o 22.09.2007, 23:10 | imax
a taky by mne zajimal vas nazor a take skusenosti s tymhle zosikem?
o 22.09.2007, 23:11 | Midi34
někdo tu nabízel za 5500,- s dohodou možnou
o 23.09.2007, 00:36 | cendler
jj já, myslím že tak kolem 5t by měl cenu, ale moc ho lidi nechtěly
o 23.09.2007, 16:27 | imax
a proc ho lidi nechteli???
o 23.09.2007, 23:08 | cendler
jo to já nevím
o 24.09.2007, 12:56 | Lucass
To jsem prodaval ja kamosovi, potom uz si udelal registraci "Hulik" tak to zkousel on a skoncil myslim na 5.000,- a neprodal, ale to uz je docela dlouho, myslim ze ho jeste ma nekde, ale ted se ho ani nesnazil prodavat.
o 24.09.2007, 13:06 | imax
a nejake skusenosti s tymhle zosikem?
Lucass proc si ho prodaval?
Stránka vygenerována za 0.3253 sekund.
