Forum > Autohifi > prosím o výpočet ozvučnice
 o Navštíveno 1099x o
o 03.05.2007, 17:19 | kondor
zdravím potřeboval bych vypočítat ozvučnici jak uzavřenku tak i otevřenou s nátrubkem jde o 25cm wofer
dík
Impedance (Z) 4Ω
Frequency range 40-3,500Hz
Resonant frequency (fs) 35Hz
Crossover frequency (12dB/oct.) (fmax) 2,000Hz
Peak rating 350W
Power rating 100WRMS
SPL (1W/1m) 93dB
Cms suspension compliance 0.55mm/N
Mms moving mass 38g
Qms mech. Q factor 3.15
Qes electrical Q factor 0.47
Qts total Q factor 0.41
Compl. equiv. vol. (Vas) 96 l
DC resistance (Re) 3.7Ω
Voice coil ind. (1kHz) (Le) 0.4mH
Voice coil diameter 39mm
Voice coil former aluminium
Air gap height 5mm
Force factor WxL 8.08Tm
Eff. cone area (Sd) 353cm2
Magnet diameter 125mm
Magnet weight 30oz.
Mounting cutout Ø 231mm
Mounting depth 110mm
Dimensions Ø 255mm
Weight 2.1kg
o 04.05.2007, 08:41 | rossi.x | Upraveno: 2007-05-04 08:43:50
Je to pro Carpower SP-252C. Mrkni sem: [ Link ]
o 04.05.2007, 19:56 | kondor
dík moc
Stránka vygenerována za 0.3326 sekund.
