Forum > Autohifi > Instal...
 o Navštíveno 1575x o
o 25.04.2007, 21:25 | DJ.UFÍK
Tak přemýšlím:oD
Za kolik je to prodejné... celkem nebo zvlášť.
"The features of the VORTEX-4/400 from CARPOWER are unparalleled in this price class."
Technické parametry
Max. power 800WMAX
RMS power 2Ω 4 x 170WRMS
RMS power 4Ω 4 x 100WRMS
Bridged power 4Ω 2 x 340WRMS
Frequency range 15-20,000Hz
Load impedance (min.) 2Ω (bridged: 4Ω)
Input sensitivity (line) 0.3-8V/ch. 1+2 50kΩ, ch. 3+4 20kΩ
Input sensitivity (high) -
Channel separation > 50dB
S/N ratio > 85dB (A)
THD < 0.2%
Low-pass 50-300Hz, 24dB/oct.
High-pass 15-300Hz, 24dB/oct.
Band-pass 15-300Hz (var.), 24dB/oct.
Subsonic see high-pass
High EQ 500-5,000Hz, ą6dB (ch. 1+2)
Low EQ 30-300Hz, ą6dB (ch. 1+2)
Bass boost 50Hz, 0 - (+12dB) (ch. 3+4)
Operating voltage 11-16V DC current /75A
Connections screw terminals
Line 2 x RCA L/R
High input -
Speakers screw terminals
Line 1 x RCA L/R
Remote control -
Admiss. ambient temp. 0-40 °C
Dimensions 300x60x465mm
Weight 6.5kg
Other features Line out (var.) HP, LP, BP, full range
a jeste
Bass attack! A vicious but enjoyable appearance with perfect features for every application purpose ..."
Technické parametry
Max. power 1,500WMAX
RMS power 2&#937; 1 x 1,050WRMS
RMS power 4&#937; 1 x 620WRMS
Bridged power 4&#937; 1 x >2kWRMS (link mode)
Frequency range 20-150Hz
Load impedance (min.) 2&#937; (link mode: 4&#937;)
Input sensitivity (line) 0.3-8V/20k&#937;
Channel separation -
S/N ratio > 85dB
THD < 0.5%
Low-pass 40-150Hz, 24dB/oct.
High-pass -
Band-pass -
Subsonic 15-50Hz, 18dB/oct.
High EQ -
Low EQ -
Bass boost 30-60Hz, 0dB - (+6dB)
Operating voltage 11-16V DC current /100A
Line 1 x RCA L/R
High input -
Line 1 x RCA L/R
Remote control RJ45
Dimensions 300x60x452mm
Weight 6.9kg
Other features Line out HP 80Hz, full range; phase shift
2 x RCA + 1 x RJ45 for link mode
o 25.04.2007, 21:26 | DJ.UFÍK
foto k příspěvku  od DJ.UFÍK
Stránka vygenerována za 0.3697 sekund.
