Forum > Autohifi > aka ozvucnica pre Emphaser EX15T3
 o Navštíveno 2215x o
o 13.06.2010, 14:05 | jasisoft
ahojte, potreboval by som pomoct s dbdrag ozvucnicou pre Emphaser EX15T3. malo by to byt do Fiat Punto MKI, rezonancka auta cca 66Hz. Vdaka.
EX15T3
Usable Frequency Response* 15 - 100 Hz
Continuous Power Handling* 700 Watts
Peak Power Handling* 1000 Watts
Nominal Impedance 4 Ohms
Voice Coil Diameter 78mm
Voice Coil Winding Height 35mm
Front Pole Plate Height 10mm
Magnet Weight 61oz. x 2
Sensitivity 87.9 dB/1W/1m
*Exact performance data depending upon actual enclosure!
Thiele - Small Parameters
Free-Air Resonance (Fs) 26.0 Hz
DC Resistance (Re) 3.9 Ohms
Electrical Damping (Qes) 0.51
Mechanical Damping (Qms) 9.9
Total Damping (Qts) 0.49
Equivalent Volume of Compliance (Vas) 119.7 l
Moving Mass incl. Air Load (Mms) 332.7 g
Electrically Limited Cone Excursion (Xmax) 12.5mm
Effective Cone Surface (Sd) 819.4 cm2
Volume Displacement of Cone (Vd) 2048 cm3
Stránka vygenerována za 0.3377 sekund.
