 Navštíveno 2288x
 18.01.2010, 18:42 |
dddd The tuner is Japanese specifications
 FM(76.1 - 89.9MHz) AM(522-1,629kHz)
znamená to to co si myslím?
 18.01.2010, 18:44 |
dddd že je to tady k prdu, když jede FM na cca 87 -108Mhz
 18.01.2010, 18:58 |
dddd FM Radio Converter
In Japan, radios are made to receive in the 76 MHz to 90 MHz band, but in other countries, you need as much as 108 MHz.
To solve this matter, we ship a “FM radio converter” with this unit for free.
The FM converter expands the range of a Japanese FM car radio right up to 108 MHz. However, the display does NOT show your local FM station’s numbers.
The converter is an add-on unit you install between your car antenna and the back side of this unit.
zná někdo nebo snad má v rádiu? jak to funguje
jj je to k prdu u nás, ale jestli funguje tady ten converter tak nejspíš nebude problém
 18.01.2010, 20:14 |
Augi někdo ho snad ještě mám, dalo mi práci jako prase to sehnat a moc to nefunguje... jsou tam přeslechy jiných frekvencí jako prase...
