Navštíveno 3743x
Tak v nedeli jedu pro ten subik, jen resim problem. Je novy ale krabice k nemu pry neni ani navod:( nevim kde mam najit nejake udaje natoz pak velikost bedny a co postavit. Posloucham nejcasteji disko rock a metal. Presne je to tenhle
[ Link ] Poradite mi rozmery a co postavit?
napis nekomu z ACR on ti udaje doda
kdyz kouknes na partnery tak Corner
nasel jsem o tom tohle. Pomuze to?
8" Subwoofer Axton AW08 , 300 / 150 Wrms, AL-Koš, 4 Ohm, 30-100 Hz, 87 Db, 1,5" cívka, PP membrána, DOPRAVA ZDARMA!.. Ozvučnice: Uzavřená-15 l, Basreflex-25 l / BR-7x20 cm, Bandpass- 10/14 l / 2xBR-7x15 cm
jj ACR je oficialni prodejce, napriklad napis na tento mejl info@corner.cz , to je jeden z prodejcu sortimentu ACR (AXTON) a myslim ze ti pomohou
dekuji za radu uz odepsal. Mam tyto udaje
Usable Frequency Response 30 - 100 Hz
Continuous Power Handling 150 W RMS
Peak Power Handling 300 Watts
Nominal Impedance 4 Ohms
Voice Coil Diameter 38 mm
Sensitivity 87 dB/1W/1m
Magnet Weight 47.5 oz. x 1
Mounting Diameter 183 mm
Mounting Depth: 105 mm
THIELE-SMALL PARAMETERS
Free-Air Resonance (Fs) 48 Hz
DC Resistance (Re) 3.1 Ohms
Electrical Damping (Qes) 0.33
Mechanical Damping (Qms) 4.8
Total Damping (Qts) 0.31
Equivalent Volume of Compliance (Vas) 10.8 l
Moving Mass incl. Air Load (Mms) 59 g
Electrically Limited Cone Excursion (Xmax p-p) 10.0 mm
Effective Cone Surface (Sd) 206 cm
Volume Displacement of Cone (Vd) 206 cm
RECOMMENDED ENCLOSURES
SEALED ENCLOSURE
Internal Volume: 15 l
PORTED ENCLOSURE
Internal Volume: 25 l
Port Diameter / Length: 1 x 7 cm – 20 cm
BANDPASS ENCLOSURE
Internal Volume Ported Chamber: 14 l
Internal Volume Sealed Chamber: 10 l
Port Diameter/Length: 2 x 7 cm – 15 cm
Z toho uz box postavit pujde? Jen porad nevim jaky typ mam delat:D
Jakou muziku posloucháš a co máš za auto?
ty objemy ozvucnic mas uz 2x napsany takze po treti...
uzavbrenka: 15 l
basreflex: 25 l
natrubek prumer / delka: 1 x 7 cm – 20 cm
bandpass
basreflexova cast: 14 l
uzavrena cast: 10 l
natrubek prumer / delka: 2 x 7 cm – 15 cm
22.03.2009, 15:41 |
axetom | Upraveno: 2009-03-22 15:45:56
Posloucham nejcasteji disko rock a metal. auto je male vw POLO . Objemy neco jsem si tam vsiml jen nevim co postavit na tento typ hudby. nekde jsem tu videl primo program na vypocet. Ma tu nekdo po ruce odkaz?vyhledavani mi nefunguje:(
jeste me napada, nema ten natrubek nejakej malej prumer? da se vubec sehnat?
na co program, objem mas znamej
a pokud chces rozmery boxu tak je to zakladni matematika
osobne bych uzavrenku
ejste se blbe zeptam. rozdil mezi uzavrenkou a BR poradite?jen me to zajima:) a co je na co lepsi
uzavrenka rychle presne basy presne to co potrebujes na rock a metal
basreflex pujde vic do hloubky ale presnost se ztraci
23.03.2009, 09:51 |
hifim@ni@k | Upraveno: 2009-03-23 09:55:09
Na to co posloucháš bude vhodnější uzavřenka. Průšvih je, že potřebuje celkem velký objem na 8". Odkazy najdeš zde:
15litru je obrovska velikost jo? :-)
Mně vychází 50L/53Hz. Není to poprvé co nějaký výrobce trochu lže :-)
ou tak ted nevim tedy cim se ridit:(ymslim litrazi:(
Pokud máš polo a budeš poslouchat tenhle typ muziky, klidně bych šel do uzavřené ozvučnice.
Tento sub je vhodný spíše do BR. Ta vychází velmi dobře.
a pokud by bl ten br tak ten objem sedi?
BR: 16L/53Hz a nátrubek 7x20cm oboustraně zaoblený. K objemu je třeba připočítat objem nátrubku a koše.
ok takze je mozny ze na ten br po pripocteni objemu tech 25l vychazi?
