Navštíveno 3495x
ahojte,
tak som odchytil maleho brasku legendarnej 15-ky...
vie mi niekto doporucit nejku SQ-*odladenu bednu
vopred diky :-)
i vloudila se chybicka: cerwin vega
Hoď fotku a TS-ka, jestli máš.
Diameter: 12”
No. of Voice Coils: 2
Sensitivity (1W @ 1m): 93 dB
Power Handling: 500 Wrms
(cont. unclipped power /ea. coil
per EIA RS-426A)
Frequency Response: 40 ~ 200 Hz
Nominal Impedance: 4 W/ea. coil
Voice Coil Diameter: 3”
Mounting Diameter: 111/8” (28.30 cm)
Mounting Depth: 4 7/8
” (12.38 cm)
Stroker 12D Thiele-Small Parameters
Free-Air Resonance: fs 51 Hz
Total Q: Qts 0.237
Mechanical Q: Qms 5.491
Electrical Q: Qes 0.248
Compliance Volume: Vas .78 ft3
Maximum Excursion: Xmax 0.9” (+0.45”)
(peak to peak) 23 mm (+11.5 mm)
Voice Coil DC Resistance: Revc 3.3 W
Effective Cone Area: Sd 83.53 in2
Driver Displacement: .15 ft3
Má dost vysoké FS, na 12". Na kolik ho chceš ladit?
BR netto 40L Port rura 10 x 29cm
12.02.2009, 20:11 |
hifim@ni@k | Upraveno: 2009-02-12 20:15:11
Nepatří u VAS 0.78 ft3 ?
hifi: Nepatří u VAS 0.78 ft3 ?
vsak .78 ft3 je predsa 0.78 ft3, amici casto nepisu "leading zero" cize nulu pred des. ciarkou
Aha, tak to je pro mně novinka. Díky.
