Forum > dB Drag Racing > Nove pravidlo pro pandy
 o Navštíveno 5512x o
o 17.11.2006, 14:59 | Kleneex
uz bude asi platit na ME zrovna se o tom bavi
Zde original text:
We have done alot of meassurements of Pandas and we have discussed this issue, and there seems to be some small diferences between Pandas. However, the judges has found a easy, fast and fair guideline to judge Street Pandas and SS NW Pandas. Remember, this is not a new rule, just a clarifications ONLY FOR PANDAS and cars that is the "same"...
I hope everyone understand this instruction, if not, post your questions in this topic.
In this picture you can see a screw that is for the plastic "pice" that is holding the original hatch. This screw (the screw that is far back) is the point that we are going to use, use a string from that point (screw hole) and to the same point on the other side (other screw hole), then your box/ports (and equipment) can not be above this line.
If you have a Super Street NW car, you also need to use a second string from this point (easy way is to just attach the second string to the string that you already has in your panda)and then hold this string down to the lowest point were the window goes down in the front doors. (were the rear side mirrors are attached). The box can not be above this line, when you hold the string tight and straight.
This shall be a easy way to do it, you may claim that its a bit low, but we have found out that this is fair for all and easy to judge and not to mention how easy it is to build boxes for pandas by this instruction.
Most, if not all, Street pandas that were in Sinsheim is below this point. BUT, you may whant to check it out if you are not sure...
Tor Aamodt
Petis hlavne ty by sis mel zmerit instalace abys zustal pod tim imaginarnim bodem pro jistotu ze by se rozhodly to fakt tak udelat :-((
zase si ku*va vymysli kraviny tyden pred ME
Buuhhhaa
foto k příspěvku  od Kleneex
o 17.11.2006, 16:07 | Pluto
Co to je za blbost? Pokud to nebude oficiálně na termpro, tak bych to neřešil a případně se hádal :-)
o 17.11.2006, 16:13 | petis
Kleneex: o tomhle už vím a sjednal jsem nápravu:-)
o 17.11.2006, 16:29 | Kleneex
jj ze to blbost vim take
uz se o tom bavi dost dlouho v USA ze bude asi tahle zmena
a mozna ze uz bude aktualni na ME
jinak to ani nemusi byt v pravidel aby jugde to prosadil bohuzel :-(
vice spor baterky Sinsheim2006
o 17.11.2006, 16:46 | Pluto
jo, to jo, záleží na Judge. To je pán soutěže :-( :-)
o 18.11.2006, 11:05 | hotdog
o co tam zhruba jde, pro ty co neumí moc anglicky, prosím...
o 18.11.2006, 12:05 | Dr.Hirax
Pokusil jsem se to přeložit tak snad se tomu dá rozumět
Udělali jsme mnoho měření Pand a prodiskutovali jsme tento problém.Zdá se,že jsou mezi nimi jen malé rozdíly.Rozhodčí našli snadné,rychlé a jasné směrnice k posuzování Street Pand a SS NW Pand.Pamatuj,toto není nové pravidlo,jen objasnění vysvětlení POUZE PRO PANDY a auta která jsou ´´stejná´´…
Doufám,že každý rozuměl této instrukci,pokud ne,pošlete své otázky v této věci.Na tomto obrázku můžete vidět šroubek „pice“,který drží tento poklop/dvířka.Tento šroubek (šroubek daleko vzadu) je hlavním bodem,který použijeme.použij provázek z tohoto bodu(závitu-díra pro šroubek) k tomu samému bodu na druhé straně (jiná díra pro šroubek).potom tvůj box (bedna) nemůže být nad touto linkou.
Pokud máš SS auto,můžeš taky použít nový provázek z tohoto bodu (jednoduchý způsob je,jen připevnit druhý provázek k prvnímu v Pandě),potom držet tento provázek dole k nejnižšímu bodu,kde okno jde dolů u předních dveří (kde jsou připevněné zpětné boční zrcátka).Bedna nemůže být nad touto linkou,pokud držíš provaz pevně natáhnutý.
Tohle by měl být snadný způsob to udělat.Můžeš tvrdit, že je to hodně nízko,ale my jsme shledali že toto je velmi dobré pro všechny a snadné rozpoznat a nezmiňuji se,jak snadné je ty bedny postavit pro Pandy s těmito instrukcemi.
Mnohé,pokud ne všechny,Street Pandy,které byli v Sinsheimu jsou pod tímto bodem.Ale můžeš to zkontrolovat,pokud si nejsi jistý…
o 21.11.2006, 12:43 | hotdog
aha, takže to jen určuje výšku instalace....
Stránka vygenerována za 0.3244 sekund.
