Forum > Ostatní > Rozměry nákl. prostoru VW caddy 2004+ ?
 o Navštíveno 895x o
o 06.01.2011, 14:51 | Pagoš
Nikde to nemůžu najít, neví někdo?
o 06.01.2011, 15:02 | .mycTD
mezi podbehama 120cm, delku neznam
o 06.01.2011, 15:04 | Pagoš
delku potrebuju hlavne :-/
o 06.01.2011, 15:05 | Pagoš
maxi má údajně 225cm, ale mě zajímá krátká verze
o 06.01.2011, 15:12 | Lukasino
hned prvni link:
It's a similar story for the body volume, which at 3.2 cubic metres equals the class-topping Fiat Doblo Cargo. As this figure suggests, it's also one of the biggest vans in its class. The 1,781mm load length is longer than the Vauxhall Combo, although only by one millimetre, while at 1,558mm wide, the load width is greater than all its rivals. Maximum width between the wheelarches is 1,171mm, which means the Caddy can easily take a Europallet on board. Six lashing points are provided in the floor to secure loads.
o 06.01.2011, 15:15 | Lukasino
a tady druhy link:
Loading Height (mm) 587
Load Height (mm) 1257
Load Length (mm) 1781
Load Width (mm) 1172 min
o 06.01.2011, 15:32 | Pagoš
výborně, díky :)
Stránka vygenerována za 0.3211 sekund.
