Forum > Ostatní > Up grade pc
 o Navštíveno 674x o
o 21.10.2009, 09:43 | choze
lidičky potřeboval bych pomoct s upgradem a to , že potřebuji tak 1T HDD na uložení záloh a rozšířit paměť aspon na 2a více G
ten hdd asi do case - napiště co je potřeba vědět pro rozšíření.
CPU-Z TXT Report
Binaries
CPU-Z version 1.52.2
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Athlon 64 3200+
Codename Venice
Specification AMD Athlon(tm) 64 Processor 3200+
Package Socket 939
CPUID F.F.2
Extended CPUID F.2F
Brand ID 4
Core Stepping DH-E6
Technology 90 nm
Core Speed 2010.4 MHz
Multiplier x FSB 10.0 x 201.0 MHz
HT Link speed 1005.2 MHz
Stock frequency 2000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Max FID 10.0x
VID range 1.100 V - 1.450 V
K8 Thermal sensor yes
K8 Revision ID 4.2
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002001h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00020FF2 0x00000800 0x00000001 0x078BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00020FF2 0x0000010A 0x00000001 0xE3D3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x72502034 0x7365636F 0x20726F73 0x30303233
0x80000004 0x0000002B 0x00000000 0x00000000 0x00000000
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F
0x80000008 0x00003028 0x00000000 0x00000000 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC001001E 0x00000000 0x00000042
MSR 0xC0010015 0x00000000 0x0C000000
MSR 0xC0010042 0x12040604 0x040C0C0C
MSR 0xC0010041 0x00002710 0x0000040C
Chipset
Northbridge NVIDIA nForce4 rev. A3
Southbridge NVIDIA nForce4 MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 1024 MBytes
Channels Dual
Memory Frequency 201.0 MHz (CPU/10)
CAS# latency (CL) 2.5
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 8
Bank Cycle Time (tRC) 11
DRAM Idle Timer 16
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Manufacturer (ID) (0000000000000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.5-3-3-8-0 @ 200 MHz
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 07 0D 0A 02 40 00 04 50 60 00 82 08 00 01
10 0E 04 08 01 02 20 00 60 70 00 00 3C 28 3C 28 40
20 60 60 40 40 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7C
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
DIMM # 2
SMBus address 0x51
Memory type DDR
Size 512 MBytes
Part number
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
SPD registers
Monitoring
Mainboard Model MS-7125 (0x0000019C - 0x005F1875)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83627THF
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0x82
LPCIO Revision ID 0x85
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 82 85 FF FE 86 00 00 FF 00 40 00 00 00 10 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Winbond W83627THF
Voltage 0 1.45 Volts [0x9B] (CPU VCore)
Voltage 1 12.95 Volts [0xD5] (+12V)
Voltage 2 3.17 Volts [0xC6] (+3.3V)
Voltage 3 4.96 Volts [0xBA] (+5V)
Voltage 4 0.61 Volts [0x26] (VIN2)
Temperature 0 35°C (94°F) [0x23] (SYSTIN)
Temperature 1 41°C (104°F) [0x51] (CPUTIN)
Temperature 2 22°C (71°F) [0x2C] (VTIN)
Fan 1 3516 RPM [0x30] (FANIN1)
Fan 2 6308 RPM [0x6B] (FANIN2)
Hardware registers
bank 0
00 01 FF 01 FF 00 00 00 00 01 01 01 01 3C 3C 05 05
10 01 00 00 00 00 01 01 3C 43 00 FF FF 24 32 00 E3
20 A0 D4 C6 BA 26 80 00 23 FF 31 6D F0 00 03 A1 60
30 48 01 9C 00 14 05 00 00 19 06 01 85 00 69 00 00
40 01 9E 00 FE FF 00 00 D0 2D 03 01 44 18 15 00 A3
50 FF FF 00 FF FF FF 00 80 90 70 FF FF 11 09 FF 05
60 A0 D4 C6 BA 26 80 00 23 FF 31 6D F0 00 03 A1 60
70 48 01 9C 00 14 05 00 00 19 06 01 85 00 69 00 00
80 01 FF 01 FF 00 00 00 00 01 01 01 01 3C 3C 05 05
90 01 00 00 00 00 01 01 3C 43 00 FF FF 24 32 00 FF
A0 A0 D4 C6 BA 26 80 00 23 FF 31 6B F0 00 03 A1 60
B0 48 01 9C 00 14 05 00 00 19 06 01 85 00 69 00 00
C0 01 00 00 FE FF 00 00 D0 2D 03 01 44 18 15 00 A3
D0 FF FF 80 FF FF FF 00 80 90 70 FF FF 11 09 FF 05
E0 A0 D4 C6 BA 26 80 00 23 FF 31 6B F0 00 03 A1 60
F0 48 01 9C 00 14 05 00 00 19 06 01 85 00 69 00 00
bank 1
50 28 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
bank 2
50 17 00 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
bank 3
bank 4
50 03 13 00 00 00 00 1E 00 17 DE 09 03 11 00 FF FF
Hardware monitor AMD Athlon 64 3200+
Temperature 0 42°C (107°F) [0x5B] (Core #0)
Hardware monitor NVIDIA GeForce 8500 GT
Temperature 0 59°C (138°F) (GPU Core)
PCI Device
Description Memory Controller
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005E
Revision ID 0xA3
PI 0x00
SubClass 0x80
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps class tHyperTransport
Caps offset 0x44
Caps revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000 MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200 MHz
PCI capability
Caps offset 0xE0
Interface type MSI Mapping
PCI registers
00 DE 10 5E 00 06 00 B0 00 A3 00 80 05 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 25 71
30 00 00 00 00 44 00 00 00 00 00 00 00 FF 00 00 00
40 62 14 25 71 08 E0 E0 01 22 00 11 11 D0 00 00 00
50 23 06 7F 80 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 00
70 44 44 00 00 D0 09 00 00 00 00 00 00 88 00 00 00
80 13 FF 88 00 FA 00 00 00 03 00 00 00 61 00 00 00
90 0E 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 08 00 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0050
Revision ID 0xA3
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0xFF
Int. Pin 0x00
PCI registers
00 DE 10 50 00 0F 00 A0 00 A3 00 01 06 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
40 62 14 25 71 00 F0 FF FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 01 00 00 FF FF
60 01 40 00 00 01 44 00 00 01 48 00 00 00 00 F9 FF
70 10 00 FF FF C1 00 00 00 00 00 45 19 10 D2 20 0D
80 09 80 00 D2 01 01 0D 00 C0 00 00 01 00 00 00 00
90 00 00 00 00 00 00 00 00 21 64 87 A9 DE BC 00 00
A0 00 00 10 41 00 00 00 00 00 00 00 00 00 00 00 00
B0 90 02 EF 02 00 00 00 00 00 00 00 00 00 00 00 00
C0 35 82 80 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 1C 10 01 00 00 00 D0 00 80 20 00 20 61 44 44 11
F0 5A FF 5F BF 00 00 00 C0 10 FF FF FF 00 00 30 07
Description SMBus Controller
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0052
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000FC00
Address 4 (port) 0x00004C00
Address 5 (port) 0x00004C40
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0x05
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 52 00 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 4C 00 00 41 4C 00 00 00 00 00 00 62 14 25 71
30 00 00 00 00 44 00 00 00 00 00 00 00 05 01 03 01
40 62 14 25 71 01 00 02 C0 00 00 00 00 00 00 00 00
50 01 4C 00 00 41 4C 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005A
Revision ID 0xA2
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE02F000
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 5A 00 06 00 B0 00 A2 10 03 0C 00 00 80 00
10 00 F0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 01 03 01
40 62 14 25 71 01 00 02 FE 00 00 00 00 00 00 00 00
50 80 00 00 00 1D 47 40 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 FF FF FF 03 10 30 07
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x005B
Revision ID 0xA3
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEB00000
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0x14
Int. Pin 0x02
PCI capability
Caps class Debug Port
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 DE 10 5B 00 06 00 B0 00 A3 20 03 0C 00 00 80 00
10 00 00 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 14 02 03 01
40 62 14 25 71 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 03 3C 3F 01 00 00 00 00
70 00 00 08 05 00 10 20 80 89 3D B6 22 77 25 44 00
80 01 00 02 FE 00 80 00 00 00 00 00 00 15 16 00 00
A0 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
B0 00 33 11 22 44 00 00 00 FF 03 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 FF FF FF 04 14 30 07
Description Audio device
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0059
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000F000
Address 1 (port) 0x0000EC00
Address 2 (memory) 0xFE02D000
Subvendor ID 0x1462
Subsystem ID 0x7585
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 59 00 07 00 B0 00 A2 00 01 04 00 00 00 00
10 01 F0 00 00 01 EC 00 00 00 D0 02 FE 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 85 75
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 02 05
40 62 14 85 75 01 00 02 06 00 00 00 00 06 01 00 21
F0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 30 07
Description IDE Controller
Location bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0053
Revision ID 0xF2
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000E000
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 53 00 05 00 B0 00 F2 8A 01 01 00 00 00 00
20 01 E0 00 00 00 00 00 00 00 00 00 00 62 14 25 71
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 62 14 25 71 01 00 02 00 00 00 00 00 00 00 00 00
50 03 F0 05 00 00 00 00 00 20 20 20 20 55 00 20 20
60 C0 C0 00 C0 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 60 CB 29 00 08 02 08 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 FF FF FF 06 15 30 07
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0054
Revision ID 0xF3
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x000009F0
Address 1 (port) 0x00000BF0
Address 2 (port) 0x00000970
Address 3 (port) 0x00000B70
Address 4 (port) 0x0000CC00
Address 5 (memory) 0xFE02B000
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 54 00 07 00 B0 00 F3 85 01 01 00 00 00 00
10 F1 09 00 00 F1 0B 00 00 71 09 00 00 71 0B 00 00
20 01 CC 00 00 00 B0 02 FE 00 00 00 00 62 14 25 71
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
50 13 00 00 15 00 00 00 00 A8 A8 A8 A8 AA 00 99 99
60 00 00 00 00 11 0C 00 00 08 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
90 00 00 00 00 00 00 00 00 06 00 06 10 00 00 01 01
A0 50 01 00 00 00 00 00 00 00 00 00 00 33 BB AA 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 02 A8
D0 0A 00 02 04 42 00 00 00 00 00 00 00 02 00 E0 07
E0 0A 00 02 04 42 00 00 00 00 00 00 00 0F 00 00 00
Location bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0055
Revision ID 0xF3
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x000009E0
Address 1 (port) 0x00000BE0
Address 2 (port) 0x00000960
Address 3 (port) 0x00000B60
Address 4 (port) 0x0000B800
Address 5 (memory) 0xFE02A000
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 55 00 07 00 B0 00 F3 85 01 01 00 00 00 00
10 E1 09 00 00 E1 0B 00 00 61 09 00 00 61 0B 00 00
20 01 B8 00 00 00 A0 02 FE 00 00 00 00 62 14 25 71
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 03 01
D0 0A 00 02 04 42 00 00 00 00 00 00 00 03 10 00 00
E0 0A 00 02 04 42 00 00 00 00 00 00 00 0F 00 60 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005C
Revision ID 0xA2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0xFF
Int. Pin 0x00
PCI registers
00 DE 10 5C 00 07 04 A0 00 A2 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 20 A0 A0 80 A2
20 E0 FD E0 FD F0 FD F0 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 04 02
40 00 00 07 00 01 00 02 00 07 00 00 00 00 00 44 01
50 00 00 FE 3F 00 00 00 00 F4 1F FF 1F 00 00 00 00
80 00 0C 00 00 00 20 57 3E 00 00 00 00 08 00 00 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
Description Bridge device
Location bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0057
Revision ID 0xA3
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE029000
Subvendor ID 0x1462
Subsystem ID 0x7125
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 57 00 06 00 B8 00 A3 00 80 06 00 00 00 00
10 00 90 02 FE 01 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 01 01 14
40 62 14 25 71 01 00 02 FE 00 01 00 00 0A 00 00 10
50 05 64 84 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0F 00 00 00 08 00 02 A8 00 00 00 00 00 00 00 00
F0 00 00 00 00 10 00 00 00 40 FF FF FF 00 04 30 07
Location bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps class PCI Express
Caps offset 0x80
Device type Root Port of PCI-E Root Complex
Port 3
Version 1.0
Physical slot #1
Presence detect yes
Link width 4x (max 2x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
PCI registers
00 DE 10 5D 00 07 04 10 00 A3 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 91 91 00 00
20 D0 FD D0 FD C1 FD C1 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 04 00
40 01 48 02 F8 00 00 00 00 05 58 93 00 00 00 E0 FE
50 00 00 00 00 A2 40 00 00 08 80 01 A8 00 00 E0 FE
80 10 00 41 01 C0 04 00 00 10 28 00 00 21 34 01 03
90 00 00 41 10 80 0C 40 00 C0 01 40 00 00 00 00 00
100 02 00 01 00 11 00 00 00 02 00 00 0A 02 00 00 00
110 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 12 (0x0C), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 2
Version 1.0
Physical slot #0
Presence detect yes
Link width 4x (max 1x)
Caps offset 0x100
PCI registers
10 00 00 00 00 00 00 00 00 00 03 03 00 81 81 00 00
20 B0 FD B0 FD A1 FD A1 FD 00 00 00 00 00 00 00 00
50 00 00 00 00 92 40 00 00 08 80 01 A8 00 00 E0 FE
80 10 00 41 01 C0 04 00 00 10 28 00 00 11 34 01 02
90 00 00 41 10 00 05 20 00 C0 01 40 00 00 00 00 00
Location bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 1
Version 1.0
Physical slot #0
Presence detect yes
Link width 8x (max 1x)
Caps offset 0x100
PCI registers
10 00 00 00 00 00 00 00 00 00 04 04 00 71 71 00 00
20 90 FD 90 FD 81 FD 81 FD 00 00 00 00 00 00 00 00
50 00 00 00 00 82 40 00 00 08 80 01 A8 00 00 E0 FE
80 10 00 41 01 C0 04 00 00 10 28 00 00 11 34 01 01
90 00 00 81 10 00 05 10 00 C0 01 40 00 00 00 00 00
Location bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x005D
Revision ID 0xA3
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
Caps version 1.1
PCI capability
Caps offset 0x48
PCI capability
Caps offset 0x58
PCI capability
Caps offset 0x80
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
Caps offset 0x100
PCI registers
10 00 00 00 00 00 00 00 00 00 05 05 00 61 61 00 00
20 00 F8 F0 FB 01 D0 F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 1C 00
50 00 00 00 00 72 40 00 00 08 80 01 A8 00 00 E0 FE
80 10 00 41 01 C0 04 00 00 10 28 00 00 01 35 01 00
90 00 00 01 11 80 25 08 00 C0 01 40 00 00 00 00 00
Description Host Bridge
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 1.02
Interface type Host/Secondary
Device number 0
PCI registers
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 00 00 E4 00 00 00 0F CC 00 0F 0C 00 00 00
80 08 00 01 21 20 00 11 11 22 06 75 80 02 00 00 00
90 69 01 61 01 00 00 05 00 07 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 3F 00 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
80 03 0A 00 00 00 0B 00 00 03 B0 FE 00 80 C0 FE 00
90 03 00 40 00 00 02 FE 00 00 00 00 00 00 00 00 00
B0 03 00 E0 00 80 5F E0 00 00 00 00 00 00 00 00 00
C0 13 60 00 00 00 F0 00 00 00 00 00 00 00 00 00 00
E0 03 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 01 10 00 00 00 00 00 00 00 00 00 00
60 00 EE E0 03 00 EE E0 03 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 45 3F 82 13 31 0B 00 00
90 80 8E 05 38 07 07 7B 3E 00 00 00 00 00 00 00 00
B0 49 9E 03 4C 1C 00 00 00 DB E9 80 08 02 93 7F 25
D0 E1 91 88 02 0C 04 02 40 54 50 27 05 38 29 80 14
E0 92 D1 D8 C9 00 00 90 00 C0 41 A0 05 04 23 C6 C8
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 03 11 00 00 00 00 00 00 00 06 00 00 80 00
40 FF 3B 00 00 40 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 40 18 EE 34
60 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 11 01 02 51 11 80 00 50 00 38 00 08 1B 22 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 00 09 00 00 10 01 80 84 00 00 00 00
B0 00 00 00 00 00 00 00 00 37 00 00 60 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 20 03 5C 07 19 05 00 00 00 00 00 00
Location bus 1 (0x01), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x1033
Model ID 0x0035
Revision ID 0x41
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xFDEFF000
Subvendor ID 0x1033
Subsystem ID 0x0035
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.1
PCI registers
00 33 10 35 00 06 00 10 02 41 10 03 0C 08 20 80 00
10 00 F0 EF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 33 10 35 00
30 00 00 00 00 40 00 00 00 00 00 00 00 11 01 01 2A
40 01 00 02 7E 00 00 00 00 00 00 00 00 00 00 00 00
E0 05 33 30 C4 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 1 (0x01), device 7 (0x07), function 1 (0x01)
Common header
Vendor ID 0x1033
Model ID 0x0035
Revision ID 0x41
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFDEFE000
Subvendor ID 0x1033
Subsystem ID 0x0035
Int. Line 0x12
Int. Pin 0x02
PCI capability
Caps offset 0x40
Caps version 1.1
PCI registers
00 33 10 35 00 06 00 10 02 41 10 03 0C 08 20 00 00
10 00 E0 EF FD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 12 02 01 2A
Location bus 1 (0x01), device 7 (0x07), function 2 (0x02)
Common header
Vendor ID 0x1033
Model ID 0x00E0
Revision ID 0x02
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFDEFD000
Subvendor ID 0x3383
Subsystem ID 0x3383
Int. Line 0x13
Int. Pin 0x03
PCI capability
Caps offset 0x40
Caps version 1.1
PCI registers
00 33 10 E0 00 06 00 10 02 02 20 03 0C 08 20 00 00
10 00 D0 EF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 83 33 83 33
30 00 00 00 00 40 00 00 00 00 00 00 00 13 03 10 22
60 20 20 3F 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 1 (0x01), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x13F6
Model ID 0x0111
Revision ID 0x10
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000AC00
Subvendor ID 0x13F6
Subsystem ID 0x0111
Int. Line 0x12
Int. Pin 0x01
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI registers
00 F6 13 11 01 85 00 10 02 10 00 01 04 00 20 00 00
10 01 AC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 F6 13 11 01
30 00 00 00 00 C0 00 00 00 00 00 00 00 12 01 02 18
C0 01 00 02 06 00 00 00 00 00 00 00 00 00 00 00 00
Description Network Controller
Location bus 1 (0x01), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x1814
Model ID 0x0302
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x02
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFDEF0000
Subvendor ID 0x1186
Subsystem ID 0x3C09
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.1
PCI registers
00 14 18 02 03 06 00 10 04 00 00 80 02 08 20 00 00
10 00 00 EF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 01 06 00 00 86 11 09 3C
30 00 00 00 00 40 00 00 00 00 00 00 00 13 01 00 00
40 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 5 (0x05), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0421
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFA000000
Address 1 (memory) 0xD0000000
Address 3 (memory) 0xF8000000
Address 5 (port) 0x00006C00
Subvendor ID 0x1462
Subsystem ID 0x0960
Int. Line 0x12
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.1
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Device type PCI-E Endpoint Device
Port 0
Version 1.0
Caps offset 0x100
Caps class Power Budgeting
Caps offset 0x128
Caps class Vendor Specific
Caps offset 0x600
Vendor ID 1
Size 36
PCI registers
00 DE 10 21 04 07 00 10 00 A1 00 00 03 08 00 00 00
10 00 00 00 FA 0C 00 00 D0 00 00 00 00 04 00 00 F8
20 00 00 00 00 01 6C 00 00 00 00 00 00 62 14 60 09
30 00 00 00 00 60 00 00 00 00 00 00 00 12 01 00 00
40 62 14 60 09 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 01 00 E0 84 2C 01
80 10 29 00 00 01 3D 01 00 08 00 01 11 00 00 00 00
100 02 00 81 12 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 04 00 01 60 00 00 00 00
130 21 81 07 00 00 00 00 00 00 00 00 10 00 00 FF 33
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 09/09/2005
DMI System Information
manufacturer MICRO-STAR INTERNATIONAL CO., LTD
product MS-7125
version 1.0
serial unknown
UUID FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
DMI Baseboard
vendor MICRO-STAR INTERNATIONAL CO., LTD
model MS-7125
revision 1.0
serial unknown
DMI System Enclosure
manufacturer unknown
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 Processor 3200+
clock speed 2010.0 MHz
FSB speed 201.0 MHz
multiplier 10.0x
DMI Processor
manufacturer Unknown
FSB speed 201.0 MHz
multiplier 10.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation A0
size 512 MBytes (double bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB0 (external)
port type USB
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI4
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 512 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 512 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
total width 64 bits
data width 64 bits
DMI Memory Device
designation A3
format DIMM
type unknown
total width 64 bits
data width 64 bits
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA NVAPI
API NVIDIA I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \.DISPLAY1
Name NVIDIA GeForce 8500 GT
Revision A2
Codename G86
Technology 80 nm
Memory size 512 MB
Memory type DDR2
Memory bus width 128 bits
PCI device bus 5 (0x5), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1462)
Model ID 0x421 (0x960)
Performance Level 3D Applications
Core clock 459.0 MHz
Shader clock 918.0 MHz
Memory clock 400.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600)
DirectX Version 10.0
o 21.10.2009, 09:50 | Knightey-
Tohle jsi jsem nemusel psat,
stacilo napsat ze mas
CPU: AMD Athlon64 3200+ na socketu 939
MG: starou na chipsetu Nvidie a pro ^^
VGA: Nvidii 8500GT
Cili potrebujes novou desku, procesor, pameti, grafiku a pak teda ten disk co pises.
Dale nevim jakej mas zdroj, jestli nejakej noname slabej, tak aby ti novou sestavu utahnul.
Co jsi vyberes za platformu je na tobe.
Ted by chtelo napsat kolik chces do toho investovat.
Jinak je to na celej novej PC. Zustane ti asi jen mechanika a mozna case :D
o 21.10.2009, 09:55 | Kamil
Knightey - nepíš nic o cpu, takže nevidím důvod měnit desku. Stačí dokoupit RAMku a zmíněný disk. Co se disku týče, přijde mi cenově hodně zajímavý 1.5TB Western Digital Green. Pokud to máš na zálohy, tak netřeba žádnýho rychlostního přeborníka a i tak má ten western přenosový rychlosti víc než slušný na to, že je to 5400RPM disk.
o 21.10.2009, 09:58 | choze
jj potřebuji jenom paměť a HDD
o 21.10.2009, 10:17 | Knightey-
Aha, sorry. Jsem myslel ze chces upgrade pc :)
Tak v tom pripade kup proste nejaky ten HDD. Akorat jsem v tomhle vypisu nensal zadnou zminku o SATA konektoru.
A nevim o tom, ze by se delalo vic jak 500GB do IDE konektoru.
Takze bud koupis vic PATA HDD o velikosti 500GB, nebo nejaky SATA radic a koupis jeden SATA disk a nebo stejne novou desku a mas klid :D
Stejne chces vic pameti a DDR2 jsou levnejsi nez ty pameti co tam mas atp. :)
Vic volnych slotu na DIMMky tam taky nevidim, mas tam 2x512MB. Takze sehnat 2x1GB alespon a tyhle prodat na aukru.
o 21.10.2009, 10:21 | Knightey-
Kazdopadne za cenu 1HDD ATA 500GB mas 1HDD SATA 1TB :)
Rozhodnuti je na tobe :)
o 21.10.2009, 10:26 | Daryl (A)
Mno, kluci maj recht. ASi bych koupil novy streva komplet.
POkud ne tak ramky co se vejde a pokud nemas sata, tak externi disk. treba externi seagate freeagent 1TB za 2600 [ Link ] a mas po starostech.
ALe je to takove zaplatovani. vymenou desky, proc a pameti ziskas hodne. Prodejem stavajicch komponent neco utrzis a upgrade nebude tolik bolet.
o 21.10.2009, 10:39 | TheTimo
choze: pokud to chceš řešit, ozvi se na ajsko, můžem něco vymyslet ;o)
o 21.10.2009, 10:48 | choze
timo ozvu
za kolik by se dali střelit ty starý střeva - deska, procák, paměti?
zdroj je ATX 2.0 chieftec
o 21.10.2009, 15:29 | Knightey-
Ten zdroj, jde o znacku a vykon.
Konkretne kolik dava Amper na 12V vetvi :)
Ostatni je "celkem" sumak :)
Pak prave nejakje 500W zdroj je lepsi jak 750W :)
Jinak chieftec je docela slusna znacka, pokud je alespon 400W tak jsi myslim ze v pohode bude dostacovat :)
Ale tak tohle vsechno proberte s TheTimem.
Jinak az budes prodavat ty stary dily, dej vedet, muzu se tady v okoli optat :)
Stránka vygenerována za 0.3543 sekund.
