Forum > Ostatní > Audi A3 zablokovana CD mechanika, help!
 o Navštíveno 632x o
o 11.03.2010, 12:27 | tappaja
Mam v tomhle aute v mechanice vlozeny navigacni DVD a nejde vysunout, pise to neco jako "mechanika je zablokovana" a tim padem si neprehraju zadny hudebni CD treba...
Nevite jak to z toho dostanu?
o 11.03.2010, 12:29 | .mycTD
nejakej reset -vyndat pojistku?
o 11.03.2010, 12:32 | tappaja
Ono spis nez chyba, tak je to tam podle me nekde nastaveny. Auto je od Sixtu z pujcovny, tak aby jim lidi treba nekopirovali navi cd nebo tak neco. Jenze to je docela scheisse dreck!
o 11.03.2010, 12:32 | Pavel 528
no jedine vyndat radio a podivat se dovnitr,pac bude neco KO na mechanice,neco se vzpricilo
o 11.03.2010, 12:38 | .mycTD
kuuurvy :-)
Channel 001: Tire Circumference
Tire circumference in Millimeter (mm) used for correcting the navigation.
Channel 002: Wheel Impulse (ABS)
Number of Wheel Impulses received by/from the ABS per Wheel turn.
Range: 4...120
Standard: 96
Channel 065: DVD Read Test
0 = Read Test not running (or to STOP Read Test)
1 = Full Rest Test (100% of the DVD are being tested - Duration: 20 Minutes)
2 = Short Read Test (Random Test of the DVD - Duration: ~30 Seconds)
Channel 066: Self Test
1 = Start Self Test
Channel 067: Ejection
1 = Eject CD/DVD
Channel 068: Ejection Lock
0 = Eject Button active
1 = Eject Button inactive (Anti-Theft)
Channel 096: Optical Performance
The optical performance of the MOST bus can be adapted/reduced for fault finding.
0 = Normal Performance
3 = Reduced Performance (-3 dB
o 11.03.2010, 12:47 | tappaja
Jojo, to bude ono jak pise mycTD, takze kulovy. iPod nemam, abych ho pichnul do prihradky spolujezdce.
o 11.03.2010, 12:51 | Pavel 528
aha,to je z pujcovny,no tak to je jasne
o 11.03.2010, 12:55 | PAVELK
kdyby si ode mně měl supíka tak se ti to nestalo :-)
o 11.03.2010, 13:53 | tappaja
che che, docela me to auto prekvapilo, mile. Ma to 103kW briketak, dlouhodoba spotreba od novyho auta 6.4l/100km, kdyz jedu podle predpisu v nemecku, tak jedu za 5.2, 30km do prace... Podvozkove motokara, fakt pekny.
Stránka vygenerována za 0.3016 sekund.
